Anti-seize on spark plug threading?
Old Feb 1, 2017 | 04:44 PM
Bmurphy380's Avatar
I plan on replacing my spark plugs this or next weekend and have been doing a good amount of research thanks to the couple of DIYs I found on here. However, I can't seem to be able to find the answer on whether or not to use Anti-seize on the spark plugs. Some say to use it, other say it messes up the proper torque setting (11-18 lb ft). What do you guys think? Any other tips?
I plan on installing all 6 Denso FXE22HR11 Iridium long-life spark plugs.
2007 Infiniti G35x - 167,000 miles
Old Feb 1, 2017 | 05:06 PM
Urbanengineer's Avatar
It was designed to go on spark plugs, so it would make a great addition.
Old Feb 1, 2017 | 05:22 PM
coffeysm's Avatar
I don't think you use anti-seize on NGK, but I'd check the instructions.
Old Feb 1, 2017 | 07:42 PM
Fire0nic3's Avatar
NGK you don't use anti seize on. They actually released a bulletin out on this.
Old Feb 2, 2017 | 07:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
Another win for the forum, thanks fellas.
Old Feb 2, 2017 | 09:01 AM
LexD's Avatar
Anti-seize compounds are composed of metallic, electrically conductive ingredients. If anti seize compounds come in contact with the core nose of the plugs, it can lead to a misfire condition.
Old Feb 2, 2017 | 09:59 AM
Huh, TIL.
Old Feb 2, 2017 | 10:27 AM
Bmurphy380's Avatar
Very interesting guys. I've been strongly considering NGK (#1406 DILKAR7B11) over Denso, but does anyone know if Denso plugs need anti seize? Should I call Denso?
Old Feb 2, 2017 | 10:28 AM
Bmurphy380's Avatar
TIL! Great info.
Old Feb 2, 2017 | 07:36 PM
saywat?'s Avatar
go on densos website and see wat they say. get it from the horses mouth
Old Feb 3, 2017 | 09:56 AM
Cbst09's Avatar
see below from the Denso site.
Torque recommendations are for spark plugs with new gaskets.
If using anti-seize compound, use sparingly and reduce torque by 30%.
Denso has created their recommendations based on the general consensus of most engine manufactures. In the case of a discrepancy between the plug manufacturer and engine manufacturers recommendations, always default to the engine manufacturer.
