New G35S Owner
The saga continues. Came back to the car after a large rain storm one day to find a huge puddle in my passenger footwell which caused me to pull the car apart in search for the leaks. Went from just fixing a leak to replacing the cluster LED'S, flickering clock LED'S etc. I have yet to just enjoy the car for longer than a week before working on it again. At least the only thing left to replace in the interior will be this crappy dashboard, which will be getting a dash cover for the time being.
Yep, leaks suck... are the rain diverters under the hood at the bottom of the windshield in good condition and not jam packed with leaves and stuff? It would be possible for water to drip down into the fresh air ducting directly behind the battery if it couldn't drain properly.
DaInfammus1
Glad to see someone successfully take on the flickering cluster and clock issue. I still have that problem and it's getting worse. Do you have instructions/pics and what exactly you did to fix them? thanks.
The car will be sitting at his shop on a lift till Hurricane Irma passes anyhow, since my M3, our bikes, and the wife's Explorer are taking up the garage currently. Don't want it exposed to the elements, especially after just fixing water leaks lol.
Mine is a coupe but it sits 1.5" lower in the front (rolled fenders) and 1" lower in the rear, +15/+25 wheel spacers F/R, stock size rubber, no rubbing at all and very happy with the ride height.
Also highly recommend a chrome delete!
I ride G
Dec 1, 2009 12:12 AM
