Compressor Clutch or Radiator Fan DIY
Old Jan 13, 2018 | 07:17 PM
ce3po's Avatar
Today I attempted to replace my compressor clutch on my 08 G35 but ran into roadblock. I thought my belt tensioner is the screw type but it turns out to be the type where you need a breaker bar. I was able to borrow a breaker bar, but there doesn't seem to have enough space between the radiator fan cooling assembly and the belt tensioner square hole for the breaker bar to fit. Afterwards, I went to Sears to get a breaker bar with rotating end but I still do not have enough clearance. Does anyone have a DIY for a 2007+ G35 compressor clutch replacement or a DIY for replacing the radiator fan assembly? Thanks.
Old Jan 14, 2018 | 07:57 AM
Mr.GEE's Avatar
20 Year Member
http://www.nicoclub.com/FSM/G35/Sedan/2007_G35_Sedan/
Try the link above. It is the service manuals for the '07. Should be the same procedure for the '08.
Old Jan 17, 2018 | 12:00 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Depends, if it's a coupe then it's a VQ37VHR motor, if it's a sedan then it's a VQ35HR motor.
Mike813
Jul 18, 2013 10:25 AM
03GT35R
Feb 10, 2012 02:04 PM
Andrei
Feb 8, 2011 04:10 PM
infinitialex
Jun 15, 2007 02:07 PM
jakeup93
Jun 18, 2005 03:20 PM
