Weird Sound
Sounds like something vibrating against something else, inspect the catalytic converter heat shields. If you have a 6MT it might be signs of the throwout bearing wearing. I recommend getting a mechanic stethoscope and finding a local lube pit to use for a few minutes to isolate exactly where the sound is coming from.
if the noise is something related to the y-pipe/heat shields, consider geting a new one. after fighting with all sorts of heat shield rattles and leaking flex sections from my 06X y-pipe for a year i finally just swapped it with a new megan racing one a couple of months ago. it was only ~$150 new and was pretty easy to install if you don't count having the cut the nuts on one side. i spent so much time under the car trying to fix the old one that the $150 seemed so cheap when it was all done.
G35-M6
Jul 24, 2019 10:46 AM
