Trunk not opening, can't find fuse or relay
Old May 22, 2018 | 10:22 AM
tjrob2000's Avatar
Anyone know which fuse or relay is for the trunk? Neither the inside button or outside button work. The door locks work, but I don't know if they are part of the same circuit.
This is on a 2007 Journey sedan.
Old May 22, 2018 | 11:48 AM
Urbanengineer's Avatar
It's likely the connection from the trunk to the body, a really common G35 problem.
Old May 22, 2018 | 12:01 PM
tjrob2000's Avatar
Ok, so how do I open it to be able to check? Or is this connection somewhere in the passenger compartment?
Old May 22, 2018 | 01:47 PM
telcoman's Avatar
Veteran: Army
Did you check the lockout switch in the glove box?
Telcoman
Old May 22, 2018 | 02:24 PM
tjrob2000's Avatar
Saw it the other day and pretty sure it was in correct position. Will recheck once water pump job is done.
trey.hutcheson
May 18, 2024 03:34 PM
izzman7
Apr 15, 2024 03:58 AM
sas555
Dec 3, 2017 04:23 PM
RCP97
Mar 12, 2017 01:00 AM
broke_as_ajoke
Aug 22, 2015 08:27 PM
