Console power socket
Old Dec 1, 2018 | 01:52 PM
Joenavy85's Avatar
G35x Base
Wanting to make the power socket have power all the time, or at least switchable. I know it's normally powered when ignition is on, but what's going to be the easiest power source when ignition is off? Has anybody else tried/done this?
Old Dec 1, 2018 | 03:40 PM
telcoman's Avatar
Veteran: Army
You neglect to mention the year or model of your vehicle?
Check out the PG section of the FSM
https://www.nicoclub.com/FSM/G35/Sedan/2008/PG.pdf
See page PG-37
Telcoman
Old Dec 1, 2018 | 07:48 PM
Joenavy85's Avatar
G35x Base
Sorry, I figured putting it in the 07-08 G35 Sedan would have been sufficient, as pretty much everything I had found show little to no difference between the 2 years. I've got an 08 G35x
Thanks for the link. I had searched on here several times trying to find links to the service manual without success.
Old Dec 1, 2018 | 08:42 PM
FreshLikeAG's Avatar
You'll have to tap into a fuse that has 12v constant power. You'll find plenty more information searching for hooking up dash cams to constant power. Same would apply for hooking up your power socket.
CD1973
Mar 5, 2008 08:32 PM
randman
May 13, 2007 08:21 PM
sliderg35
Apr 27, 2006 07:09 PM
