07 G35 (vq35de) dipstick reading over H?
Old Feb 17, 2019 | 02:29 PM
Daniel Alvarado's Avatar
VQ35DE 6 speed manual g35
07 G35 dipstick reading over H?
Can’t really see but if you look carefully the dipstick is covered in oil... should I be worried?
Anybody know why my oil dipstick isn’t reading after engine is warm?
It reads correctly before I turn the engine is warm but after the dipstick is covered in oil... did oil change about 1500k miles ago so I know im not over.. what f*** is going on???
Old Feb 17, 2019 | 04:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check your oil first thing in the morning before the engine has been started for the day, it's 100% fool-proof reading.
Old Feb 17, 2019 | 04:46 PM
I did this morning, just kinda threw me off when I checked the oil again and the dipstick was full of oil.. added a quart so I’ll recheck tomorrow morning.. is this normal, though? Should I be worried at all?
Old Feb 17, 2019 | 06:52 PM
Scorpi0's Avatar
Holy damn! I've never seen it that high lol.
Wipe it off conpletely. Put it back in. Let the car sit overnight and check it again in the morning.
Old Feb 17, 2019 | 07:11 PM
cleric670's Avatar
BANNED!!!
If you ran the engine AT ALL before checking the oil then it's completely normal. That's why I strongly recommend only checking the oil level on a cold motor.
Usually the only time you start getting more oil volume on a gasoline motor is if you blow the HG and it fills the crankcase with oil.
Deisel engines it's semi-common depending on the motor because blowby fuel ends up in the crankcase.
Old Feb 18, 2019 | 07:51 AM
Blue Dream's Avatar
I drove ttrank's car solo
It's a known fact that on the first gen VQDE motors it's useless to check the stick when the engine's hot because oil is all over the dipstick. Cleric has great advice as I suspect the HR motors have the same issue. Also I've moved this thread to the appropriate place, the sub-forum you postedit in specifically says at the top in bold red print "No Car Questions".
Old Feb 18, 2019 | 09:07 AM
Hall Stevenson's Avatar
Can you edit the thread title too (??) because '07 models don't have the DE engine
Old Feb 18, 2019 | 09:57 AM
I got into a debate with a guy who claimed to work on Nissan and Infiniti vehicles for 20 years telling me this way of checking is absolutely wrong. He insisted you must warm up the engine, then let it sit for 15-20 minutes before checking. Apparently in his 20 years of automotive experience doesn't realize why the dipstick goes into the sump.... Whatever.... I check mine in the morning after it's sat in the garage 8+ hours and that works just fine for me !
Old Feb 18, 2019 | 10:33 AM
I have the coupe.. still a 35DE, I believe only the sedan came with the HR in ‘07...
checked oil this morning and looks normal, appreciate everyone for the advice!
Old Feb 18, 2019 | 03:08 PM
cleric670's Avatar
BANNED!!!
@Hall Stevenson lol that's awesome. He probably had 20 years experience working at the parts counter and zero experience checking oil level.
Old Feb 19, 2019 | 09:12 PM
saywat?'s Avatar
this is what it says in the manual:
"CHECKING ENGINE OIL LEVEL
1. Park the vehicle on a level surface and
apply the parking brake.
2. Run the engine until it reaches operating
temperature.
3. Turn off the engine. Wait more than 15
minutes for the oil to drain back into the oil
pan.
4. Remove the dipstick and wipe it clean.
Reinsert it all the way."
so its not too crazy what the guy said. but me i do it in the morning
Old Feb 19, 2019 | 09:53 PM
Yeap, I know the manual says that but the reality is, it's just not practical. From the convenience side of things, there's no way they're going to suggest "allow the vehicle to sit for 1 hour or longer before checking the level".
Old Feb 19, 2019 | 10:25 PM
saywat?'s Avatar
I wish they would.
Old Feb 19, 2019 | 10:49 PM
Scorpi0's Avatar
temperature.
pan.
Lol...yeah...good luck with that method.
Old Feb 19, 2019 | 11:02 PM
saywat?'s Avatar
G37 manual says wait 10 mins lol
