P1550 code: Battery current sensor
Old Sep 20, 2019 | 09:08 PM
Cabrito's Avatar
07 G35S 6MT
2007 G35S 6MT. Scan tool gives P1550 DTC, bad battery current sensor.
Apparently this has to do with adjusting the load on the alternator. I can't seem
to find a part number for the sensor. No symptoms.
Is this worth investigating further?
Thanks
Old Feb 8, 2020 | 08:32 PM
ARahG35's Avatar
G35x
I have the same issue. It doesn’t really affect the car much I’ve had trouble starting from time to time in cold weather.
Old Feb 8, 2020 | 09:06 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Usually it's a bad connection on the sensor disconnect the battery, unbolt the sensor, use a wire brush and clean up the mating metal parts thoroughly, apply electrical anti-oxidation grease, bolt it back together.
G35-R
Engine - Intake/Fuel
Apr 4, 2015 03:03 PM
painter8
Feb 9, 2014 08:30 AM
kelvinhair
Drivetrain
Dec 31, 2013 11:18 PM
DGrantG
22
Jun 11, 2013 12:14 AM
logicalloco
Jun 19, 2011 09:15 PM
