Need advice on buying a car
Old Oct 16, 2019 | 04:47 AM
hankinsrichard7's Avatar
G37
Hi guys, I'm a new here. Help my with buying a car. I found it here https://incacar.com/used/cars/infini...TI-G35-531994/ what do you think about this deal? Thanks for answers.
Old Oct 16, 2019 | 06:47 AM
eazdaskeez's Avatar
For the amount of money you'll spend to get it back to running condition you might as well get one that's key and go. Will you be doing the work yourself? If not then yes that's an easy pass
Old Oct 16, 2019 | 10:17 AM
909's Avatar
909
Your mom's boyfriend
Buy the most you can reasonably afford.
So if you got it , spend it.
A lot more options around 5-6k and even more around 10k .
But if all you can spend is 2-3k , buy the newest, lowest mileage car you can find.
I personally wouldn't buy anything from a place called GOTCHA !
Old Oct 16, 2019 | 11:27 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If you are a good frame and body guy sure, if not I would pass on it. You can usually find a lightly bumped car that needs only 6-10 hours of repair for 3500-4000 range. That car is going to need major work and hours to be right again.
Old Oct 16, 2019 | 12:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That car is going to need the left front unibody chopped out and replaced, if you're trying to rebuild it for a daily driver I would pass.
However if you just need an HR powertrain at a reasonable price then that's a pretty damned good deal since you get engine/tranny/diff/wiring harness/ECM/etc...
Old Oct 17, 2019 | 03:25 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
From someone who owned a collision shop for 20 years, No,No,No. You can get a good example for 5-10 depending on year model and just drive it. To me considering what replacement parts would cost(particularly if you have to buy a lot of new parts) all it would be worth is about what it weighs. Again, I'd take a pass on it.
Frank Yin
Jun 22, 2009 02:06 PM
treydawg
May 21, 2008 11:31 PM
minoz35
Jul 3, 2007 08:30 PM
