07 g35 sedan power loss no check engine light
Old Sep 30, 2020 | 01:21 AM
Donald Castro's Avatar
g35 sedan 6MT
As you can see my car has been trippin But idles fine.it’s also weird that my Navi blacks out and my interior lights get super bright before it happens
I replaced:
fuel pump
battery
passenger side cat(dealer said crack on the cat was causing the problem) still same issue
brand new crank sensor
cleaned maf and throttle bodies
Old Oct 6, 2020 | 07:55 PM
g35 sedan 6MT
Fixed: ended up being an alternator issue. The alternator was overcharging hitting around 20 volts at high rpm causing it to cut power. I replaced alt and it’s good as new.
Old Oct 10, 2020 | 07:33 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Glad you updated the thread with the fix, first time I've ever seen that issue before.
Old Oct 10, 2020 | 03:53 PM
g35 sedan 6MT
I figured, this was happening for over a month and o was doing really extensive research And found nothing, even went to the stealership and they told me this was a clogged cat issue smh.
But yea hope this helped someone. Check ur alternator voltage could be charging too much!
alt failed due to very small ps pump leak that dripped onto the alt... who’s bright idea was to put the alt directly under the ps pump 🤦🏻‍♂️ It’s about time to replace the pump anyways cheers!
Donald Castro
Oct 6, 2020 07:54 PM
Arock020.
Aug 22, 2020 03:12 PM
Al-x Rivera
May 1, 2020 10:30 PM
NIROMU
Dec 5, 2013 07:25 PM
skizg35
Feb 7, 2010 02:30 PM
