In fail safe or limp mode
Old Oct 12, 2020 | 08:55 PM
Ant2021's Avatar
Stock
07 X I have the A/T light on the dash and I’m stuck in fail safe or limp mode. Fluids are good. No Check Engine light
Old Oct 16, 2020 | 11:34 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Ignore the P1815 for now, that's a minor inconvenience and probably just the microswitches on the shifter.
The other 3 codes are all related to the TCM not getting data from the ECM, disconnect the battery and get the car in the air and look for damage on the transmission harness, unplug the harness and look for corrosion/damage to the pins. Engine speed and throttle position data are all sent via CANBUS and you have a CAN communication error so that's likely where the problem lies.
Check the TCM harness as shown in the FSM.
Old Oct 16, 2020 | 09:48 PM
Ant2021's Avatar
Stock
That means I have to drop the tranny Pan and remove the valve body correct?
If the harness is okay what could be the next possible issue?
thanks for the feedback
I appreciate the help
Ant2021
Oct 7, 2020 08:24 AM
Featster
Jul 13, 2019 01:54 AM
pilotd
Drivetrain
Feb 17, 2009 12:41 PM
Jony
Intake & Exhaust
16
Jul 12, 2007 07:52 PM
Boston
Sep 25, 2006 11:14 PM
