Telescoping wheel won’t raise...?
Old Nov 9, 2020 | 12:14 AM
ForceOfWill's Avatar
G35S, sedan, 6mt
Hey there! Super new to G’s, and honestly I’ve never had a car with power telescopic steering installed haha. The control works, it goes in and out, and it goes down...but won’t go back up at all. I didn’t hear anything but it wouldn’t go back up away from my legs.
Is there something I can replace here? Do I have to replace the whole motor for the steering column? Is this common? I didn’t have much luck in the search.
Thanks!
Old Nov 9, 2020 | 10:53 PM
dr_dangus's Avatar
G35x w/ Premium and Navigation
Likely the gear setup in the column. Looks like Dorman sells a replacement kit here for just the gears, if you are mechanically inclined.
Old Nov 10, 2020 | 01:16 AM
G35S, sedan, 6mt
i was thinking the gears, but I feel like I would at least hear it trying if it was a stripped gear. It makes no noise going up, but sounds like a normal motor going in/out/down. I’m suspect of the switch... wondering if that’s a part I can buy individually lol.
Old Nov 15, 2020 | 04:47 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'd unplug the switch so you know exactly what the harness looks like then buy a used one on eBay or find a local G in a pick-n-pull.
Old Nov 18, 2020 | 01:28 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Is this harness a complete plug in off the main one and would it acting up affect different warning lights i.e. seat belt light, turn signal indicators or is that an altogether different problem. I lose one occasionally and can move the column just a bit and they're back on.
dynamik
Apr 25, 2013 11:23 PM
khezik
Sep 15, 2011 02:49 PM
BimmerGuyFL
V36 General Tech Questions
Jun 20, 2008 02:17 PM
Geniusjustin
Dec 10, 2006 01:29 AM
