some system stop working, front console (radio, a/c, power seat;windows, rear defog)
Old Nov 12, 2020 | 06:54 AM
sergebandeja7's Avatar
Unhappy some system stop working, front console (radio, a/c, power seat;windows, rear defog)
need help with issue, 2008 G35x. while driving, my front console stop working the monitor just going off, no power on my radio, a/c stop working too, power seat, rear defog, rear brake light, the switch in the **** for transmission too stop working for me to move the **** i used the screw driver for manuel release the transmission ****, and i ve some light go on im my panel cluster ( the abs light...) but the car start correctly. i check for burn fuse, but every thing is good (all fuse in the IPDM are good)
Old Nov 15, 2020 | 04:48 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like you blew something in the fusible link.
Old Nov 15, 2020 | 06:56 PM
After hour in troubleshooting, I found my problem. The connector behind the fuse box was disconnected. I was checking the continuity of the fuse, that why all fuse was good but was not powered.
The connector was the link between the battery and the fuse box under the steering wheel
TheBay
Aug 27, 2015 05:08 AM
Feeelax
Oct 1, 2013 06:48 PM
neo_anderson302
May 31, 2012 11:15 AM
ctk519
Feb 19, 2010 03:10 PM
JPDD
Jan 3, 2007 03:52 PM
