P2A00 and P0850
Old Aug 22, 2021 | 04:53 AM
rsthomas's Avatar
Post P2A00 and P0850
Hi
I have a 2008 G35 and I have a SEL light on with the following codes. Any thoughts on troubleshooting ? Appreciate the help in advance.
Car Scanner ELM OBD2
DTC report
Selected brand: Infiniti
VIN: JNKBV61F98M256799
============1==============
P2A00
Raw code: 2A00
ECU: Engine control unit
Status: Confirmed
OBDII: Heated oxygen sensor (HO2S) 1, bank 1 - circuit range/performance
============2==============
P0850
Raw code: 0850
Status: Pending
OBDII: Park/neutral position (PNP) switch - input circuit malfunction
Infiniti: Park / Neutral Switch Input Circuit
============3==============
P2A00
Raw code: 2A00
Status: Validated fault present at time of request, Validated fault has been present during this drive cycle
============4==============
P0850
Raw code: 0850
Status: Validated fault has been present during this drive cycle
Old Aug 22, 2021 | 01:00 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The PNP switch is a pretty easy fix, screws into the side of the transmission.
P2A00 can be a few things but most commonly it's a vacuum leak.
Old Aug 22, 2021 | 01:08 PM
cleric670's Avatar
BANNED!!!
You should inspect the PNP switch before just replacing it, it should be the one at the rear of the transmission on the passenger/right side I think.
Old Aug 22, 2021 | 08:38 PM
rsthomas's Avatar
@cleric670 Thank you!. I will start looking at this. Is there a video or instruction that you are aware I can use to poke around ? Also about the vaccum leak, is there a way to narrow that down by ourselves ? or should I take it to a mechanic ?
Old Aug 22, 2021 | 09:14 PM
cleric670's Avatar
BANNED!!!
I'd just try to spin the various vacuum lines by hand. If you can twist them they are leaking. Also remove and inspect the intake pipe for any cracks/tears/etc. Typically they happen at the corrugated flexible part.
Old Aug 23, 2021 | 04:39 PM
rsthomas's Avatar
Thank you!. Will try these out.
gcoupe_toronto
Canada
Feb 10, 2011 12:36 AM
andiz35
Mar 4, 2008 01:30 AM
rupdog326
May 6, 2006 04:23 PM
