Broken ignition coil bolt
Old Mar 6, 2022 | 12:57 AM
Steevie's Avatar
G35x
So I've recently got a 08 G35x and the bolt on Cylinder 3 broke so im getting a P0300 code so I'm not sure if that's maybe causing that code to pop up TIA!!
Old Mar 6, 2022 | 10:19 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably not, pull and inspect all plugs, use an extractor to get that broken bolt out.
Old Mar 6, 2022 | 11:57 AM
Steevie's Avatar
G35x
Would a misfire cause car to idle at 1k rpm by chance? But also I'm getting p0304 but I have it's a feeling it's cause I put an older coil pack in there but the p0300 I'm not sure what's causing that my mechanic said I have a vacuum leak and wanted to charge me to inspect but I currently don't have the funds so once I do I'ma have him inspect it but also my car doesn't idle weird or nothing it just stays at 1k rpm does jump at all or nothing just stays there and once I put it on drive it drops underneath 1k so will that misfire cause that high idle
Old Mar 6, 2022 | 12:25 PM
cleric670's Avatar
BANNED!!!
P0300 just means there's a misfire, P0304 means it's specifically on cylinder 4.
1000 rpm idle is definitely high and usually caused by a vacuum leak. Check out the PCV lines from intake-valve cover-across to other valve cover-back up to intake plenum and make sure they're all tight and cannot be turned easily by hand. If they can be easily rotated then put a hose clamp on those ones.
Also remove and inspect the intake tube for any rips/cracks/tears, particularly at the accordion flexible sections.
Old Mar 6, 2022 | 12:32 PM
Steevie's Avatar
G35x
So I changed the pcv valve but didn't check the lines I'm going to be buying new silicone hoses down the road but I will check them and hopefully it's just a bad hose and also I did have a rip near where they go over on the tb I replaced that one on the passenger side and on the driver side I did see like a crack by the flexing part of the tube but didn't seem to be cracked fully through the other side so can that maybe be it?
DeafBringer
Jan 18, 2016 06:14 PM
rsingerG35
Feb 9, 2014 05:18 PM
OMG35S
May 6, 2011 12:58 AM
OMG35S
V36 Engine, Exhaust, Drivetrain & FI
May 5, 2011 09:38 PM
Linner
V36 General Tech Questions
May 6, 2008 12:35 PM
