NA or FI
Old Oct 14, 2022 | 05:26 PM
pathnotfound's Avatar
Stock for now
NA or FI
I've been looking at building my engine and I've noticed that it doesn't look like much power is gained from NA mods but I've seen some pretty crazy power figures from FI builds would it be more worth it to wait for a while and save to do a FI build or not. obviulsy i can do the basics like intake exhaust and stuff of that sense but should I go any further than that or is it kind of wasted money at that point?
also to those who have done a FI build how much should I be expecting to pay I know its not cheap but most of the kits I've seen are over $10,000
Old Oct 14, 2022 | 06:54 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you doing the work yourself or paying a shop?
Old Oct 14, 2022 | 07:49 PM
Stock for now
I plan to be doing as much as i can myself i’ve got the garage space and tools to do so
Old Oct 14, 2022 | 09:48 PM
cleric670's Avatar
BANNED!!!
Ok well the stock rods can handle 450whp so keep that in consideration. Supercharged is the least expensive, new is roughly $7k complete, used kits are typically half price but you may need the compressor rebuilt which is another $750 or so and a used kit also typically doesn't include the UpRev license/software/cable so figure another $750 for that as well.
If your metal fab skills are up to par you can make your own hot/cold side and go turbocharged for about the same price. Single eBay turbo and you can cheap out on a lot of stuff but definitely spend the money for a good wastegate. Don't bother with a boost controller to start with, just run it on the gate spring until you get everything else ironed out and put rods/pistons in.
I wouldn't plan on more than about 8-10 psi with stock piston/rods and a supercharger, 6-8psi with a turbo.
The Stillen kit for the HR has a great reputation.
Old Oct 17, 2022 | 06:47 AM
The-Dream's Avatar
Don't forget a nice bling BBK set.
Brackets:
https://www.z1motorsports.com/z1-pro...t-p-27529.html
Carbon Ceramic Rotors:
https://www.amsperformance.com/produ...brake-package/
R35 OEM Calipers:
https://www.ebay.ca/itm/275361598048...evt=1&mkcid=28
R35 OEM Caliper Rebuild Kit:
https://www.z1motorsports.com/front-...t-p-13344.html
https://www.z1motorsports.com/rear-b...t-p-13350.html
Old Oct 20, 2022 | 07:42 PM
No Boost's Avatar
G35x/Cayman S 3.8L
https://www.z1motorsports.com/nfs/st...charger%20Kits
Well under $10k, including the tune. The one reviewer states he/she is making a bit over 400 whp, about 100 more than a full bolt-on N/A but still safe for the stock rods.
Whitey09
Intake & Exhaust
11
Feb 12, 2010 01:15 AM
madnaz
Intake & Exhaust
May 31, 2008 01:47 PM
battlebuddyP
Jun 5, 2007 03:11 PM
varelis617
Jan 1, 2007 07:56 PM
vt_maverick
Mar 25, 2006 01:17 PM
