08 G35S Budget BBK?
Old Feb 21, 2023 | 12:43 AM
Robert Kinney's Avatar
G35S 6M
08 G35S Budget BBK?
Hey everyone,
My stock brakes on my 2008 G35S 6MT are on their last legs and I've been looking into doing an upgrade. I found a video on how to do a cheap Brembo upgrade on the earlier 350Zs and I was curious if it would be applicable? I know there were some suspension and brake changes but I was unsure of how the bolt patterns would line up.
If anyone's done this or has any advice on something like it, I would greatly appreciate it! Here's the link to the video:
Thank you!
Old Feb 22, 2023 | 01:23 AM
BPmaik's Avatar
since the G also came with Brembo's they bolt directly, I do believe the bolts are longer for Brembo's and you'll need the lines as well. Might need to modify the dust cover to fit them if you can't get a hold of the brembo one or take it out completely.
The Akebono caliper's from the 370/G37 are also a popular option but you'll need to buy a bracket to fit that bolt pattern.
Old Feb 25, 2023 | 01:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The issue you'll find with doing the "rebuilt swap" like suggested in that video is there's usually another $75-$100 CORE CHARGE for the calipers.
That puts it all about in-line with just buying a set of Brembo's on eBay.
As for compatibility, the V35 and V36 chassis can interchange brakes, you will need the rotors, and sometimes the short brake lines/banjo bolts for whatever caliper you're switching to.
The V36 chassis came with the Akebono BBK as a factory option, the early V35 came with the Brembo BBK as a factory option. Dust shields almost always have to be trimmed, not a huge deal. The Akebonos will also require an adapter bracket and there's a few people making them, usually $100-$150 for those brackets.
xilio
May 15, 2013 07:58 PM
pharrari
Video Share
May 20, 2008 11:55 PM
08g35s
V36 Audio, Video & Electronics
Dec 7, 2007 11:43 PM
GThIrtYFiZle
Future Models
Mar 21, 2007 09:48 PM
