07 G35 sedan won’t stay on
Old Mar 12, 2023 | 05:10 PM
Juanvq35's Avatar
05 G35 coupe and 07 g35 sedan
07 G35 sedan crank and sort of starts
I have a v36 07 g35 that I recently did spark plugs and coil packs for and it ran and drove fine after. It was idling a little weird since the rpms moved up and down a little but I assume that’s because the intakes were all cracked. I let it sit for a while, maybe a week(crazy rain during this time) and when I went to start it again, it had a dead battery. I also noticed a fat puddle of water on my passenger side. Charged the battery and it cracks and start but stalls immediately. Now I read a lot about the sunroof drains and the bcm going out so I fixed the drain, cleaned all the water under the carpet, got a new bcm, and reprogrammed it. Still won’t run. Thought it maybe a vacuum leak, changed the intakes tubes, breather hose, cleaned the mafs sensors and throttle bodies but nothing. I changed my crankshaft too before it started not running since it would have long cranks when starting. I double check to make sure all my coil packs were connected right and checked under the battery tray for water but it was just dirty and I cleaned it. Kinda lost what it could be but if any of you have any information or ideas what it could be, I would appreciate it a lot. Does not throw any codes btw
Old Mar 17, 2023 | 10:15 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take apart the IPDM engine bay fuse box and see if it's wet inside.
Old Mar 20, 2023 | 04:49 PM
Juanvq35's Avatar
Did that already too, double checked today and it’s dry. I even made sure it was closed properly.
Old Mar 23, 2023 | 12:51 PM
Juanvq35's Avatar
This is pretty much what happens every time I try to start it up. Gassing it doesn’t do anything either, it just stays on a bit longer but eventually stalls.
File Type: mov
Old Mar 27, 2023 | 10:55 AM
cleric670's Avatar
BANNED!!!
Might be a wet ECM as well, take off the kick panel and inspect the primary harness for the ECM, pop the screws on the ECM cover and see if it's wet inside.
Miss.Bosslady
Jun 24, 2022 11:36 AM
Az35x
Sep 26, 2021 06:49 PM
JChristopher
Oct 27, 2018 07:55 AM
lung
Jul 16, 2012 11:12 AM
nismo714
Aug 15, 2009 08:34 PM
