Help with A/C not blowing air
Old Jun 15, 2023 | 04:54 PM
lazz0645's Avatar
2008 g35s
Hello, I went through a car wash and somehow it shot water into my blower, I replaced the blower, the fuses and checked the relay. Not sure what other options I have and would love some input on what to check next. I want to try and avoid taking it somewhere. Thanks in advance. I have a 2008 g35s
Old Jun 16, 2023 | 12:50 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Not sure how it would shoot water into your blower motor. There is a cover over the battery box, then the cabin air filter, each would be preventing water from getting into the blower motor.
Unplug the blower motor harness and verify it's getting power. If it's NOT getting power then it's probably something in the IPDM engine bay fuse box got wet and blew a fuse, or the fusible link.
Did you swap the blower relay with another relay to verify that it's actually working?
Old Jun 21, 2023 | 07:02 PM
lazz0645's Avatar
2008 g35s
when I was fixing my car the last time it broke I forgot to put the battery cover back on correctly, honest mistake.
I switched out the relay and it seems to be good, I replaced the blower motor and the both the fuses, as well as switching the dash a/c control panel. I can hear the blower spinning just no air is coming from the vents or the defrost vents.
Old Jun 24, 2023 | 10:47 AM
cleric670's Avatar
BANNED!!!
If you take off the glove box you can see the mixer motor/linkage on the side of the heater core. Check to make sure it isn't visibly broken. You can move the mixer AC control from feet, front vents, defrost vents and watch the motor and linkage working.
Where is it currently blowing air from? Feet?
Sirduke731
Aug 26, 2017 09:18 AM
albert3029
Jul 10, 2013 04:44 PM
develop1
Jun 27, 2011 06:32 AM
AARONHL
Jul 31, 2009 02:39 AM
