tips to remove stuck on pcv middle hose on valve covers?
Old Jun 21, 2023 | 08:28 PM
Darelle700's Avatar
g355
Old Jun 23, 2023 | 12:43 AM
Scorpi0's Avatar
Pull harder? Twist as u pull?
Use a tiny flathead screwdriver to pry the rubber hose off of the tube. Stick it in between the tube and the hose. Then keep workin your way around as u spray some soapy water over it. Hose should break loose and slide off.
Old Jun 24, 2023 | 10:49 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I usually grab them with small channel locks to get it to spin initially.
Worst case scenario you cut a slit in it with a knife and buy a new one.
Abdul Kelani
Dec 27, 2019 12:07 PM
Blitz1350
Jun 27, 2009 09:32 AM
markiev37
Jan 25, 2008 04:00 AM
bendu
Mar 11, 2007 11:02 PM
