Fixed Brake Fitment questions?
Old Jul 17, 2023 | 08:10 PM
maxbalahura's Avatar
Silver paint, black interior currently wrapped in china blue.
Hey guys, 08 g35xs owner here
I will be doing some suspension maintenance and id figured i can hit the brakes while im in there. Found a fixed caliper setup from rockauto but it supposedly fits only 08 g37’s. Is there a bracket that can make these fit? Or do they bolt on no problem, i feel like the website is wrong for some reason? Because the g35/37 sedan are very similar. I will put a picture of them below. Also… if they do fit? What pads and rotors do i use with them? It would be different then stock i assume.
Old Jul 22, 2023 | 10:20 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Parts can interchange if you swap caliper/bracket/lines/rotor.
Why would you not just replace with the same caliper though? You can get OEM Nissan rebuild kits for them too usually, do you have the regular calipers or the Akebono ones?
Ground Beef
V36 Brakes, Suspension, Wheels & Tires
Jul 11, 2014 09:32 AM
hrdwirk1
Nov 22, 2012 10:18 PM
kejolly
Nov 30, 2010 01:02 AM
DRKNYT
Aug 28, 2010 01:48 PM
jimk
Dec 3, 2009 04:01 AM
