Longshot attempt for any Infiniti mechanics
Old Jun 27, 2024 | 05:09 PM
Bill Di Marco's Avatar
G35x
Angry Longshot attempt for any Infiniti mechanics
U1000 code service engine soon light any ideas?
Old Jul 4, 2024 | 02:11 PM
99zx2turd's Avatar
check this thread: No start u1000 code please help - G35Driver - Infiniti G35 & G37 Forum Discussion
Old Jul 25, 2024 | 06:56 PM
$KYLINE's Avatar
The U1000 code is a generic code to indicate that there was a CAN communication failure. With a decent scanner you should be able to view additional modules to see what else may have been throwing codes.
Check for water intrusion. As mentioned above, the IPDMs on these cars are a common issue, but the other modules are not exactly safe since the sunroof drains run to the firewall. If the drain fittings get brittle and the foam seal breaks down, you will have moisture in the car at some point. If pull up the carpet and the foam insulator to check for water in the floor panel.
thass23
Jan 31, 2015 11:29 PM
G35 Owner
Dec 18, 2010 12:15 AM
mclem17
Apr 8, 2010 10:51 AM
Jay-G
Intake & Exhaust
Jun 12, 2009 03:35 PM
