A/C Compressor control problem
Old Jul 9, 2024 | 08:10 PM
Joenavy85's Avatar
G35x Base
So a few weeks back I replaced my compressor with a new unit and had the system evacuated and charged at a shop. Fast forward to actually needing to use it and it barely cools at all. I had a can of A/C Pro and hooked it up to check the pressure and the pressure is reading high on the low pressure side. I've checked to make sure the clutch engages, and when it does the pressure drops slightly. I also replaced the drier/receiver as well as the expansion valve. The only thing I can think of is either the compressor control fuse is blown or the plug doesn't connect solidly. Has anybody else had this problem before? Thanks.
OneSlowG35
Jun 27, 2025 08:05 AM
blackandwhite
Jun 15, 2021 02:02 AM
JRandallC
Apr 17, 2016 10:12 AM
Tim4G
May 17, 2008 08:32 PM
