G35X lighting issue
Old Mar 4, 2025 | 11:45 PM
ramirez32385's Avatar
G35X
G35X lighting issue
G35X
jumped it the other day, it turned on but now the instrument cluster doesn’t turn on, I see that all the dummy lights flash and also the lights on the push start button and also the lights on the ac/heater unit. What can be the cause? I did notice once I moved it the lights on the dashboard were turning on and off plus you can see the needles that want to jump
Old Mar 6, 2025 | 07:51 PM
G35X
Here is a video
File Type: mov
Old Mar 9, 2025 | 09:55 PM
MaLPoPieS's Avatar
Jaguar XFR-S
I would start with the battery and grounds. Google FSM for your car and get busy.
Old Mar 10, 2025 | 09:05 PM
G35X
Noticed today that the bright illumination on the instrument panel also blinks on and off as you drive
Old Mar 10, 2025 | 09:39 PM
MaLPoPieS's Avatar
Jaguar XFR-S
Alternator would be the first thing i'd test/replace. Take a look at it from the top passenger side if it's juicy from the power steering pump secretions that's right above it.
That's the Top 3 alternator killer in the VQ35HR engine setup..
Connect a DVOM to the battery while engine is ON and see if the voltage goes up and down or fluctuates.
tutajodio
Lighting
Sep 28, 2011 07:40 PM
xjayflyx
Sep 15, 2009 11:17 PM
306HP
Mar 17, 2008 01:07 PM
bmfgsxr
Jan 28, 2008 10:44 AM
