G35Driver Feedback & Suggestions NO Car Questions! For posting Feedback, Suggestions or Questions regarding G35Driver website ONLY.
Is my iTrader broken?
Old Aug 14, 2010 | 12:26 PM
NFSP G35's Avatar
? = 2B || !2B
Why does it say "Positive Feedback: 11" but "Total positive feedback: 13" ???
Is it 11, or 13
https://g35driver.com/forums/itrader.php?u=87333
(also, sorry if this is the wrong area?)
Old Aug 14, 2010 | 12:32 PM
Calvin's Avatar
Overglorified Altima
It's not counting the one from GUEST and only counts Candlestickpark once.
Old Aug 14, 2010 | 12:34 PM
NFSP G35's Avatar
? = 2B || !2B
Wait... a guest sent me feedback???
--edit: WTH? I don't even remember this?!? https://g35driver.com/forums/itrader...=16801&u=87333
Old Aug 14, 2010 | 12:35 PM
Calvin's Avatar
A+ forum member, thank you!
Rating Already Submitted Edit / Delete Feedback Report Bad Rating
Seller Guest (N/A) 09-29-2009
Old Aug 14, 2010 | 12:37 PM
NFSP G35's Avatar
? = 2B || !2B
IDK what that was all about
Thanks for clearing that up Cal
Calvin's Avatar
Yah, not sure what that is about or how it happened. I just tried signing out and leaving you a negative iTrader. Didn't work.
Old Aug 14, 2010 | 01:05 PM
NFSP G35's Avatar
? = 2B || !2B
^Gee thanks
Old Aug 15, 2010 | 09:01 PM
Calvin's Avatar
But now that I'm signed back in...I can leave you a negative iTrader.
Old Aug 15, 2010 | 09:05 PM
NFSP G35's Avatar
? = 2B || !2B
^I'm not sending you any more shiny nickels!
Old Aug 15, 2010 | 09:08 PM
Calvin's Avatar
I bought the HELLA Supertone horns with those nickels.
Old Aug 15, 2010 | 09:10 PM
NFSP G35's Avatar
? = 2B || !2B
^ I've had a set on the sedan for a while now.
I love scaring our horses when I drive by
Old Aug 15, 2010 | 09:12 PM
Calvin's Avatar
^^^Did you install the included relay or did you do a direct swap/plug'n'play install?
Old Aug 15, 2010 | 09:28 PM
NFSP G35's Avatar
? = 2B || !2B
^Direct swap.
A friend gave them to me and didn't have the relay.
I'm going to redo them with a relay and some heaver wire, because they're not as loud as they were on my other car, and they sound goofy when you lock the car and it "chirps" them (in fact, I turned off that feature)
Old Aug 16, 2010 | 09:19 PM
Calvin's Avatar
So did you use a relay when they were on your other car? o.O
Old Aug 16, 2010 | 09:20 PM
NFSP G35's Avatar
? = 2B || !2B
^No, the Trans-Am had better wiring (surprisingly)
magnetism80
Feb 1, 2019 10:00 AM
jeffbdye
Jun 1, 2018 03:51 PM
itgogitrev
Sep 23, 2015 07:08 PM
