G37 Coupe V36 2008+ Discussion about the G37 Coupe
Looking for some info
Old Aug 8, 2020 | 06:14 PM
eazdaskeez's Avatar
So either imma swap my engine with a lower mileage one, install a new head or just sell it and move on
I'd rather keep it because it's mint and I've swapped an engine before so it's no big deal to me
I really need to know one thing though. Can you remove the awd engine just as easily as the rwd engine? I read some information over at Myg37 that said the awd motor cant be removed from the top due to clearance issues. Doesn't sound to right but wanted to confirm. Thanks.
Old Aug 9, 2020 | 01:49 PM
eazdaskeez's Avatar
Anyone 👀
Old Aug 9, 2020 | 11:35 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I haven't had the pleasure of looking under the hood of an X in person, so I'm not much help. However, I know that the AWD cars have the front diff mounted next to the oil pan on the passenger side. I don't know you can remove the front diff whilst the engine is in the car.
Old Aug 9, 2020 | 11:37 PM
eazdaskeez's Avatar
Ahhhh your absolutely correct.
But if I split the trans and the engine I should be ok I'm thinking.
Old Aug 10, 2020 | 12:58 PM
eazdaskeez's Avatar
Daily bump 👀
Old Aug 10, 2020 | 04:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The front driveshaft goes THROUGH the oil pan on the AWD version, plan for removing it, iirc you just unbolt the flange on one side and pull off the axle on the opposite side. Sometimes bellhousing bolts are hard to get off if the front driveshaft is really close to them.
Old Aug 10, 2020 | 04:10 PM
eazdaskeez's Avatar
Thanks cleric! That's what I was hoping and you save the day again as usual lol. Iirc one side of the axle has 6 bolts to remove the half shaft and the other side is the usual pop out
Old Aug 11, 2020 | 06:12 PM
eazdaskeez's Avatar
Anyone else have any info to add?
Old Sep 3, 2020 | 11:10 AM
projectpanda13's Avatar
I don't have any information to add with regards to dropping teh AWD motor, but wanted to provide some information on your next motor.
Try to find a 2015 motor from a Q50. it's a direct drop in, already has the new updated gallery gasket, has better headers, and heads (unconfirmed).
alex.brenneman
Media Share G35 Sedan V35
Jan 17, 2018 11:41 AM
Gikosta
Jan 24, 2017 03:23 PM
Clevermedicine
Jun 19, 2012 02:15 PM
onevoice
Nov 22, 2011 07:38 PM
asma123
Aug 24, 2010 10:46 PM
