What am I missing here...
Jul 2, 2013 | 11:07 AM
Besides the grill. Got knocked out by some road debris, and just wanted to make sure I wasn't missing any equipment that should be showing up behind it.
Thanks for looking
Reply 0
Dec 12, 2013 | 11:24 PM
Nope...everything is all there
Reply 0
Dec 12, 2013 | 11:33 PM
That bumper has seen better days.
Reply 0
Dec 19, 2013 | 03:55 PM
Thanks. Yup, needs a real good wash and some touch-up paint.
I've still got the insert and trying to figure out how I'm going to re-attach.
Reply 0
Dec 27, 2013 | 11:40 PM
That hole is for a tow hook I believe. There should be a tow hook threaded for it in the trunk that you can attach incase you get clumsy enough to drive into a ditch and need a tow truck to winch you out.
Reply 0
Dec 28, 2013 | 01:26 AM
Grille
Reply 0
Jan 9, 2014 | 01:41 PM
That' lower grille is about 100 dollars if it gets lost or knocked out
Reply 0
Jan 14, 2014 | 11:13 AM
Still have the grille, only problem is the screw tabs got sheared off. So it's going to be some kind of glue job (or maybe it can be screwed in some how, hidden).
Reply 0
Jan 14, 2014 | 11:17 AM
JB weld on a small metal bracket, then attach with small bolt and lock nut.
Reply 0
Jan 14, 2014 | 09:59 PM
Quote: JB weld on a small metal bracket, then attach with small bolt and lock nut.
Yeah that seems like a good idea that way it isn't permanent.
Reply 0
