General Media Share Find and share Infiniti-related videos! Just took some pics for fun? Looking for general pics and vids? Try it out. Please post specific media (Mods, etc.) in its specific category in the Tech Area.
Powerlab G35's
Old Apr 28, 2008 | 05:52 PM
  #46
VeilSideBrian's Avatar
WOW!
awesome!!!!!
Old Apr 28, 2008 | 05:53 PM
  #47
SlideFox's Avatar
Originally Posted by VeilSideBrian
WOW!
awesome!!!!!
It already beat it's last time....
http://my350z.com/forum/showthread.php?t=355444
Old Apr 29, 2008 | 08:53 PM
  #48
Sportcoupe35's Avatar
nice nice nice...
Old May 27, 2008 | 09:43 AM
  #49
bgoldst's Avatar
nice shots
Old Jun 18, 2008 | 01:28 AM
  #50
Its-A-G-Thangg's Avatar
What kit(or front) does the blue G have on it?
Old Jun 18, 2008 | 02:28 AM
  #51
SlideFox's Avatar
Top Secret
http://www.intensepower.com/topfrbug35co.html
Old Jun 18, 2008 | 03:07 AM
  #52
HenryLee's Avatar
looking good..
Old Jun 18, 2008 | 01:49 PM
  #53
INTENSEPOWER's Avatar
Thumbs up
Originally Posted by krnn1cenamja
looking good..
Thank you!
Old Jun 18, 2008 | 01:52 PM
  #54
Those are G's are rediculus! I couldnt imagine the money and time put into them
Old Jul 22, 2008 | 12:22 AM
  #55
sTony's Avatar
kind of a dumb question, and i'm not sure this is the spot for it.. but for the powerlab kit.. what are necessary mods to run it safely? exhaust i'm sure. gauges. clutch and flywheel necessary? rods even if its running a mild tune, say 6-8psi? I'm trying to calculate all the necessary add-ons i'm gonna need before going through with it w/spracing.
Edit: forgot about bumper but yeah, add that in there
Old Jul 22, 2008 | 02:45 PM
  #56
Hello,
To answer your questions:
1. If you're not going to build your motor, we recommend NOT installing a boost controller. The default wastegate spring is .3 bar (4.41 psi), which is a very safe boost level for this motor. You can opt for a different spring if you'd like to make more power, but PowerLab will (as most companies do) always want to err on the side of safety first. Depending on if you have a revup or non-revup motor 5psi will get you anywhere from 350-380 whp.
2. A rear section exhaust is recommended. Like other single turbo kits on the market for this application, true dual and cat-back exhausts do not mate up to the mid-pipe that is provided with the kit. Therefore, you can retain your factory rear section, or any aftermarket rear section (like GReddy SP2, JiC, Apexi, etc). Gauges are a good idea --especially boost and egt (or wide band). A clutch that will support the additional torque that's created is a good idea, otherwise you will decimate your factory clutch w/ the quickness.
3. The front bumper is fine, but it's always recommended to use an aftermarket one with a wide opening in the front middle. GReddy and Top Secret are obvious options, but there's others out there as well.
Anything else that you need answers on, please don't hesitate to post them up, PM or call us. Hope this helps.
D
Old Apr 1, 2010 | 04:08 PM
  #57
Mr_pharmD's Avatar
is there pix of the intake that goes into the turbo? I know the 350z have a hole but is the intake pipe different or will it need to make a hole to fit the pipping?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
