G35 Sedan- Do w0rk!
on
on
Its the Tanabe Medallion exhaust. It sounds great on the car. The muffler is a little ridiculous,though.
The car has gunmetal Volk GTU's on it before, so the grey sections blended in well.He just picked up a Stillen SC, so that will go in over the winter. He's tying to decide if he wants a kit or to leave it stock body before doing any paint...
Looks good. I think if the rims were 1" larger it would look a lil better, fill the gap between the side of the fender and the wheels. Also, painted sills would look a ton better.
kennymo, sidewall is thin because from the looks of it, it's goin for an aggressive setup. Can't have fit tires for that, especially when tryin to obtain offsets goin towards the negatives.
ill Sedan
on
Maybe take off a couple of the rings? I know my Stance has extra rings on the fronts and from what I've seen with most coilovers that have the oem spring setup, they have 2 rings you can take off as well. Should give you an extra .5" and with the rear you can also do the spring mount mod.
ill Sedan
on
