Help on changing the temperature display unit.
Old Apr 3, 2007 | 01:25 AM
JJKK's Avatar
I am trying to change the unit of the temperature from ℉ to ℃
I tried looking up in the owner’s manual, but did find anything there.
Please help. Thanks
Old Apr 3, 2007 | 01:16 PM
JJKK's Avatar
anyone know how to do this??
or is it even doable??
Old Apr 3, 2007 | 09:00 PM
dave's Avatar
I don't remember anyone actually making this change.
The only thing that I have seen that looks promising it is in the wiring diagram (in the service manual) for the Automatic Air Conditioner system. It shows pin 14 of connector M31 only exists for Canadian models. It shows that pin connected to Ground for Canadian models. Then above pin 14, it says "C/F". This is all on page atc-47 of the factory service manual for my 2004.5 coupe.
This may mean that if you connect pin 14 of connector M31 to ground that it would display in C. But then again there could be more to it...
Old Apr 3, 2007 | 09:05 PM
izmir41500's Avatar
G35driver Addict
why would you want to, unless you're used to seeing C? it may be a pain in the @ss but good luck to you. i'd get more info from dave ^
Old Apr 4, 2007 | 12:57 AM
JJKK's Avatar
damn.. that's too much works.... but i might try it some other time..
thanks for the help, i just hope it could be as easy as the nissan quest..(one button changes it)
yah~ i am actually used to seeing C since that is what we use back in Canada & Taiwan, but i guess i will just have to get use to the F here.....
arora_g35
Apr 16, 2026 02:52 PM
Frostbite91
Aug 20, 2015 07:20 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
