HELP: fuse location
Old Nov 15, 2007 | 08:16 AM
gtowner's Avatar
HELP: fuse location
anyone got a pic of the interior fuse box? I pulled out one but forgot which slot to go in
btw, which fuse control all the lighting stuff? my friend tried to install my new headunit and doing some wiring stuff, but after put back on the center console light, parker light and taillight are all went off. the map light, headlight and speedometer light are all working fine. please it's urgent!!!
Old Nov 15, 2007 | 09:34 AM
clifftrail's Avatar
Don't know about the interior but there is a fuse box located behind the battery against the firewall in the engine bay, remove the trim around the bat and you will see it, that is where your blown fuse is probably at. GL.
Old Nov 15, 2007 | 11:44 AM
DrewTheSuit's Avatar
+1 if you lost your radio lights, parking lights, and taillights it is the fuse behind the battery........edit thought i'd spread the love with the same link i was given when i blew that fuse
https://g35driver.com/forums/lighting/151433-side-marker-fuse-blown.html
Old Nov 15, 2007 | 11:54 AM
g35rcr's Avatar
one by the driver side footwell and one behind the battery
Old Nov 15, 2007 | 02:02 PM
TroysG's Avatar
step 1: find your car's manual (most of the time they are in the glove box that only allows you to fit the manual in it)
Step 2: open the manual - I suggest looking in the index in the back under FUSE
Step 3: READ YOUR MANUAL
Old Nov 15, 2007 | 02:18 PM
Gfan's Avatar
Come on dont be a dick. I don't know since I never changed one or looked for it. Sorry, I wish I could help. GL though
Thanks!
Old Nov 15, 2007 | 02:21 PM
Rodrigo's Avatar
to my knowledge there is one under the hood near the battery and the other by the drivers left foot rest.
Old Nov 15, 2007 | 06:06 PM
gtowner's Avatar
Thanks for all the reply. I will try to check the box behind battery today.
I checked the interior one it's all fine but I pull out one fuse forgot which slot to go in, anyone can help?
my car is imported from *** and no manual for my car, that's bad.
Old Nov 16, 2007 | 08:48 PM
i just changed this same fuse like 5 days ago follow the link i supplied, it even has the fuse you need to replace circled...it is in the fuse box behind the battery, fuse location is in the top left corner...i believe it is a 10a
Old Nov 17, 2007 | 02:13 AM
gtowner's Avatar
problem all solved. just the taillight fuse is blown. easy lol
Old Jan 10, 2008 | 09:15 PM
shdowflare's Avatar
https://g35driver.com/forums/showthread.php?t=151433
You are a GOD. I just had this fuse blow on me tonight. No tail lights, radio lights or parking lights after installing my new clock bulbs. Now I know which circuit I'm working with in the fuse box.
Old Oct 20, 2008 | 05:27 PM
xcessiveskllzz's Avatar
Turbo G35 coupe single turbo with some goodies
both passenger and driver heated seats don't work...possibly a fuse problem? anyone know where the heated seats fuse is located?
Old Nov 24, 2008 | 02:25 PM
paky786's Avatar
I bet it's the second or third fuse box near the battery! If you don't know how to access it, you have to take off the black coverings for the battery and windshield. I'm almost 90% sure that the problem is there
G35-R
Nov 7, 2015 01:21 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
2014g35x
Sep 11, 2015 07:53 PM
pasjr1972
Sep 1, 2015 10:17 PM
