Buzzing sounds when ABS/VDC kicks on driving through snow
Old Dec 5, 2007 | 04:08 PM
RADIOGUY21's Avatar
We just got some snow here in Chicago, and yesterday was the frist day I drove my car in snow/slippery conditions. I have snow tires installed which were probably the best purchase I made. Anyway, I noticed whenever the ABS engaged from lost traction or the VDC going off, it would make this wierd sound similar to the ABS system self test noise at startup but it was consistent to however long the system applied the brakes. I dont really know how to describe it, but it was like a loud buzzing sound each time it went off, i could kind of feel it vibrating through the pedal so i know it has to be from the ABS. I went to an empty parking lot and tested it out furthermore and noticed everytime the car would begin to lose traction, the VDC would counteract and use the ABS/brakes to correct the car (which is normal) but everytime it did that it made that sound. I think it is normal, only because it makes the same exact sound the ABS system self test makes, only for longer duration. Again this is only when the car loses traction, setting off VDC/ABS. But i just want to clarify with you guys and see if anyone else ever noticed it.
Old Dec 5, 2007 | 04:13 PM
Hi-TechG35's Avatar
It's normal. Mine does the same thing too.!
Jeff92se's Avatar
Red Card Crew
Normal. Sounds like someone is rolling a marble across the floor.
Old Dec 5, 2007 | 04:28 PM
f r e z N Y's Avatar
Some even think that it sounds like a spring being tensioned.
Old Dec 5, 2007 | 05:54 PM
RADIOGUY21's Avatar
awesome, i figured it was normal. It is pretty wierd sounds though, kind of scared me at first. Any idea why it makes these noises when you lose traction? And i had the "spring being tensioned" sound on the tip of my tongue, couldnt describe it at the time but thats a great description for it. Thanks again guys.
Old Dec 5, 2007 | 06:58 PM
Gilley's Avatar
That's the sound of the VDC at work. It's a good sound to hear if you need VDC.
Old Dec 5, 2007 | 07:09 PM
kvangil's Avatar
Yep, it's normal. I believe it's the sound of the fuel being cut off to prevent you from accelerating at that moment. That's just my speculation though, since it sounds like my old Maxima did when it had bad injectors....
Old Dec 5, 2007 | 08:31 PM
O HELLA OEM's Avatar
i was wondering the same thing..phew i thought my brakes went bad or something b/c everytime i lost traction and brake i hear a bzzzzzzzzz sound...
Old Dec 7, 2007 | 04:53 PM
jayjay1122's Avatar
Not to throw another wrench in the works here, but for some reason I was hearing this in the snow yesterday as well, but I turned VDC OFF and it still made the sound...
Anyone ever heard it with their VDC turned off??
It kinda freaked me out!!!
Old Dec 7, 2007 | 06:43 PM
Jedunnigan's Avatar
ABS still works.
Old Dec 8, 2007 | 10:47 AM
Gilley's Avatar
Turning off the VDC button does not completely turn off VDC. You have to pull the brake fuse.
chinee
Jun 10, 2024 07:48 PM
Terry_G35
May 9, 2020 01:39 AM
Terry_G35
Aug 4, 2015 02:38 PM
bjo16
Aug 4, 2015 09:52 AM
kinetek
Aug 3, 2015 04:25 PM
