Big problem with heater/AC
Old Dec 19, 2007 | 11:40 AM
Strtsk8r321's Avatar
Thumbs down Big problem with heater/AC
When the a/c is set to 60 degrees cold air blows out but when its at 61 or higher the air is really hot. Any ideas on what could be causing this?
Old Dec 19, 2007 | 11:52 AM
LjN_728's Avatar
I'm leaning towards the thermostat being on the fritz. Bring the issue up to the dealer during your next oil change. Look on the brighter side...it's freaking rain and cold as ufck!
Old Dec 19, 2007 | 12:19 PM
g35rcr's Avatar
you have a sensor below the steering column that has to be plugged into the lower dash assembly...it looks like a hose and there is an electrical clip connection...make sure the hose is connected or it will blow either 60 or 90 air and nothing in between
Old Dec 23, 2007 | 02:04 PM
^ Thank you
Old Feb 15, 2008 | 03:08 PM
kuhntar's Avatar
I have this same problem now, does anyone have a more detailed instructions for this? I see a hand full of different electical connections but I am not sure which one is it, I felt around and it seemed like all of the connections were securely in place. But still getting 60 or 90.
Old Nov 14, 2008 | 04:04 PM
AARONHL's Avatar
I have the same problem, as all my connections under the steering wheel are connected properly. What is causing this? Did you ever fix the issue?
Old Nov 16, 2008 | 08:48 PM
pattyskin's Avatar
The dealer had fixxed this problem for me in the past, they charged me 1 dollar to plug it in.
Old Nov 17, 2008 | 08:11 AM
uf20wop's Avatar
did they really charge you $1
Old Jun 23, 2009 | 03:09 AM
DEMoLITIoN's Avatar
fuxk. i still have this issue. any fixes?
Old Jun 29, 2009 | 11:04 PM
machspeed's Avatar
damn ... I hv the same issue...
Old Jun 29, 2009 | 11:23 PM
machspeed's Avatar
yeaH ... I fixed it ... 1 min job
Thx a lot
thx for the info
ThanQ
Old Jun 29, 2009 | 11:36 PM
g35ryder19's Avatar
ey guys i have a 2003 coupe that i bought used. i have a problem i put the air all the way down on 60 and doesnt feel that cold and i have the fane on like 4 notches can this b my thermostate or do i need a recharge of freeon?????
Drifter2090
Dec 26, 2015 12:10 AM
Mick_L
Aug 25, 2015 04:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
