A/C not cold enough?
Old Jun 30, 2009 | 01:18 PM
GoDaddy's Avatar
I find my A/C not cold enough .... what could cause this? Do I need to refill some liquid or something ?
My car is a 03 coupe ... quite old...
Old Jun 30, 2009 | 03:52 PM
parhamm1's Avatar
Just get your AC recharged. Should fix the issue. I know some other members have some different remedies, but a simple recharge will probably be the easiest.
Old Jun 30, 2009 | 03:59 PM
GT-ER's Avatar
You you find it warmer than it used to be or do you find that you car has always been this way? A recharge would help if the gas is somewhat low but in my car I replaced the oem fans with high flow aftermarket fans and it helped a lot.
Old Jun 30, 2009 | 05:51 PM
GoDaddy's Avatar
recharge, how do I recharge the AC ... sorry for the noob question.
Recharge as refilling some liquid? Is there a DIY?
Old Jun 30, 2009 | 05:52 PM
GoDaddy's Avatar
after some research .. recharge on freeon?
Is that easy to do? DIY somewhere
Old Jun 30, 2009 | 06:12 PM
parhamm1's Avatar
Make it really easy on yourself and just go get it done by a reputable shop. It's not expensive, especially if you have a coupon for a place like Pep Boys or Autozone to do it. Normally I would never suggest taking the G to one of these places, but for something so simple I'd say it's fine. There are also DIY kits. I'm sure a simple google search for recharging AC would do you good. Nuff said.
Old Jun 30, 2009 | 06:48 PM
LjN_728's Avatar
Freon is no longer available at the local Pep Boys, or at least it shouldn't be. Only available to certified mechanics. My mechanic charges $20/lb. I've never tried those AC recharges kits from the store.
Old Jun 30, 2009 | 07:49 PM
ttrank's Avatar
Grocery getter
I still get Freon at the store. At least I did a few months ago. But make sure the right amount goes in because if you put too much in you'll have the same issues.
Old Jul 1, 2009 | 02:55 AM
tt88supraman's Avatar
my AC takes a while to get cold. like a min or 2... is that mean i need to recharge my AC also?
Old Jul 1, 2009 | 08:20 AM
OBG3506's Avatar
^^ No thats just residual heat in the system from sitting, but it does eventually get cold, right?
Old Jul 1, 2009 | 01:31 PM
yup...
G35Rican
Jul 31, 2024 01:37 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
JLee301
Sep 25, 2015 08:46 PM
mattdg35
Sep 14, 2015 11:28 AM
