Rear view mirror rattle
Old Aug 18, 2008 | 07:42 PM
Ginu's Avatar
Anyone who has opened the rear view mirror by any chance?
I can't seem to be able to open the damn thing so i can dampen it with something.
Old Aug 18, 2008 | 08:22 PM
afr0puff's Avatar
Supa Dupa Moderator
It's just a snap seal. Stick a thin flat head screw driver in between the seam. You'll need to do it in several locations. Also, be careful cause the screw driver will mark the delicate plastic. I just put a dab of silicone sealant on anything that might rub. Also ran it all alone the seam and them wiped the excess when the two halves were rejoined.
Old Aug 29, 2008 | 08:16 PM
Smeghead's Avatar
My mirror rattle was because the screw that attaches the mirror to the windshield bracket was not tight. A few days after snuging the screw up nice the bracket came off the windshield. Once I glued the bracket back on and tightened up the screw not quite so tight it has been good.
Old Aug 30, 2008 | 12:43 AM
infinus's Avatar
I had a rattle problem and thought it was my mirror but it turned out it was my sunglasses rattling from the subwoofer haha.
mjfenix
Aug 17, 2017 05:49 AM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
