Trunk opens with key fob but not with button inside car
Old Sep 9, 2008 | 09:41 AM
mousenmbr1's Avatar
I have an 05 coupe and this morning I noticed that the trunk will not open with the button to the left of the stearing wheel. I then hit my key fob open button and it worked. I have read the thread about other problems people have had with there trunk not opening but it seems like there problem was that it wouldn't open at all with both the button and the key fob.
What could the reason be for this not working with the button in the car? I checked the wires running to the trunk and there are none cut. Could this be a fuse? It isn't the harness right? Because if it was it wouldn't open at all right? I'm going to check the fuses tonight when I get home from work but just wanted to get some suggestions as to why one would work and one wouldn't.
Thanks guys.
Old Sep 9, 2008 | 10:09 AM
RBull's Avatar
Rated M
Mine does the same thing sometimes. I find if I turn ignition on it seems to reset and work. I can't help with why.
Old Sep 9, 2008 | 11:00 AM
Glex25's Avatar
Administrator
sounds like the switch in the glove box might have gone bad.
My car did the same thing but that was my stupidness that i broke the switch.
I have it held together with electrical for meantime but it works.
Old Sep 9, 2008 | 11:12 AM
mousenmbr1's Avatar
Where is there a switch in the glove box for the trunk?
Old Sep 9, 2008 | 11:15 AM
Hi-TechG35's Avatar
Open your glove box and look to left corener inside. It's dark in there so you may want to use a flashlight.
Old Sep 9, 2008 | 11:18 AM
Glex25's Avatar
Administrator
might just be switched off.
I broke mine doing the in cabin filter on the back side
Old Sep 9, 2008 | 01:32 PM
mousenmbr1's Avatar
great info guys, it was just the switch in the glove box. I had never seen that before.
Old Sep 9, 2008 | 01:34 PM
BlueDevilBAMF's Avatar
And, there's a red nylon strap between the back seats if you dig down in there... if you pull it you can get the seats down from inside the car!
(sorta on-topic of things most people don't know )
Old Sep 10, 2008 | 06:41 AM
mousenmbr1's Avatar
Yeah that red strap really has come in handy multiple times. It is weird how no-one really knows about it being there, stuff is hidden all over this car...
Old Sep 19, 2008 | 02:16 PM
BostonG6spd's Avatar
where is this red strap?? I cant find it
Old Sep 19, 2008 | 02:26 PM
ShanesG's Avatar
^just put your hand in between the seats, in the middle, you'll feel it
Old Sep 24, 2008 | 10:29 PM
infinus's Avatar
whats that stupid little cap in the top middle of the seats? I haven't figured out what its for yet.
chinee
Jun 10, 2024 07:48 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
apintojr
Jul 23, 2015 10:52 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
