my guage cluster blinking like a christmas tree HELP!!!!
Old Sep 15, 2008 | 10:29 PM
dannyboi2088's Avatar
ok so recently sometimes when i start my car up the e-brake, vdc, and skid(when you lose traction) those 3 light up......and when i turn my car off and then on right away it still stays on........but when i leave it off for a while then turn it back on then it goes away
also sometimes while i'm driving the e-brake light will turn off while the other 2 stay on.......anybody have a suggestion whats causing this??
Old Sep 15, 2008 | 11:02 PM
ohh yea and im lowered on tein basics with stock 17" rims.....i dont know if that matters but do i need to go to the dealership or can i get that fixed somewhere else......i don't want them charging me 5K when i could spend WAYY less somewhere else that does the same job
Old Sep 16, 2008 | 07:29 AM
fbpem1's Avatar
check your brake fluid level could be as simple as that....
then check your brakes becuase you probably need brakes on the car.
Old Feb 13, 2009 | 09:51 AM
Kinma's Avatar
did you find an awswer to the blinking problem? My car is doing the same thing and now my headlighta are always on, my wipers dont work, my signals dont work, my speedometer works somtimes, my temp gauge doesnt work all the time, my traction control is not working either and the lights says off bc my buttonwont work, and all the lights in my cluster are flickering or on all the time.
Any one have any suggestions to whats going on? Is there a short somewhere?
Old Feb 16, 2009 | 04:07 PM
BW350GTskyline's Avatar
my Gauge cluster the other day actually froze from some reason
g.spot
May 9, 2016 10:54 PM
Blue Dream
Dec 5, 2015 10:56 AM
wow600rr
Sep 28, 2015 11:50 AM
vamarris
Sep 26, 2015 12:56 PM
