Very Wierd Noise Today...help
Old Nov 4, 2008 | 05:27 PM
SolidGround's Avatar
Driving back from work on my 03' coupe 6mt i heard a weird noise. Can anyone help diagnose the problem or am I just paranoid?
Story is I'm due for an oil change about 1k miles ago and to make matters worse I got a flat this past weekend. So I drove it to work on the spare today. Coming home on the highway as I was decelerating on a right angle to an on-ramp I heard a weird rubbing noise. It happened twice but only lasted about 2 secs each times and I'm not sure where it came from since I had the music on as well. But I did notice that during the noise my (clutch) slip light blink on each time it rubbed.
Now is this a sign that my clutch is going bad? This happened before but not in the same scenario. Plus it's been a couple months since it happen and I've been driving it almost everyday since I've had it out of storage in March.
At first I thought I didn't tighten the spare tire enough and that might be causing the sound but I tried to re-tighten the lug-nuts and they were fine.
Is it a coincidence or does it have something to do with oil, spare tire, clutch or other? Please any help or input is appreciated.
Thanks
Old Nov 4, 2008 | 05:31 PM
elayman's Avatar
probably just your tires are a little bit different size than ur spare so one of the tires is spinning faster and it thinks its slipping
Old Nov 4, 2008 | 05:33 PM
dofu's Avatar
20 Year Member
Change out the spare... if the sound is still there, then worry.
Old Nov 4, 2008 | 05:44 PM
Thanks guys that makes me feel a little better.
Let me know though if I should be worried for anyone reading this post afterwards....
Thanks
Old Nov 17, 2008 | 04:32 PM
tom's_Z's Avatar
Sounds like the traction control is activating when you lose traction on the spare. Just change it, you should be fine.
06g35
Feb 14, 2022 05:59 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
