Help: Rewiring Parking Lights to be on when car is on
Old Mar 2, 2009 | 01:58 PM
RPL's Avatar
RPL
Like the title says, I want to re-wire my parking/city lights to be on 24/7 when my car is on, not just when lights are on, in my '03.5 Sedan.
I was wondering if you guys could help me about how would be the best and safest way to rewire the lights, and perhaps guide me to what would be the best constant 12v source from the engine bay.
Thanks.
Old Mar 2, 2009 | 03:04 PM
MyocyteX's Avatar
There is a switch for that right?
Old Mar 2, 2009 | 03:49 PM
KPierson's Avatar
Won't that kill your battery after a day or two?
Should be pretty easy - wire a relay up like this:
Pin 86 - Ignition
Pin 85 - Ground (diode from Pin 85 to Pin 86 with stripe facing Pin 86)
Pin 30 - 12vdc
Pin 87 - Parking light output at BCM
You should be able to find all these wires at the drivers side BCM - grab a service manual and it should be pretty simple.
Old Mar 2, 2009 | 03:51 PM
06g35meister's Avatar
he wants daylights. i have no idea how to do it, but im sure it can be done as the Canadian models have this stock.
Old Mar 2, 2009 | 03:56 PM
WILLIE BEANS's Avatar
turn the hedlight switch on the left side of the steering wheel once ??
Old Mar 2, 2009 | 04:05 PM
KPierson's Avatar
parking lights won't work as daylight running lights. There is a thread on here somewhere where a guy rewired his fogs to be daylight running lights - that's a little closer to "real" DRLs.
The Canadian cars have a completely different setup that uses a dedicated DRL module. If I remember right it's not a simple retrofit.
Old Mar 2, 2009 | 06:23 PM
RPL's Avatar
RPL
Yeah, I don't want them on when my car is off, I just want them on whenever my car is in the on position. So, yeah, daylights. And I don't want it to be the side lights as well, just the parking light in each headlight.
With that being said, KPierson, will your recommendation still work?
arora_g35
Apr 16, 2026 02:52 PM
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
ghost_g35
Aug 7, 2015 10:31 AM
Karl_g335x
Aug 3, 2015 03:43 PM
