Has anyone upgraded their horn?
Old 03-01-2010, 01:05 PM
STCLAIRWEST's Avatar
Wow that train horn is crazy, anyone try using a firetruck horn?
Old 03-05-2010, 12:43 AM
akw's Avatar
akw
akw is offline
Hella Supertone
Old 03-05-2010, 12:47 AM
TIAN's Avatar
Hold The Line
Our horns aren't loud enough?
Old 03-05-2010, 09:33 AM
akw's Avatar
akw
akw is offline
I did mine mostly for cosmetic but the extra db is nice with the way most drivers around my area drive haha
Old 03-05-2010, 04:39 PM
fstrthnlfe00's Avatar
Old 03-05-2010, 04:54 PM
Alan's Avatar
hmmm tempting... our stock horns are so quiet!
Old 04-15-2010, 12:41 PM
speedjunkie_G35's Avatar
I have been thinking of finding a horn with a more exotic sound like a lambo's.
Old 04-15-2010, 12:53 PM
WILLIE BEANS's Avatar
Originally Posted by fstrthnlfe00
HOOOOLLLYY MOLY .. lololol
Old 04-15-2010, 01:20 PM
bythabay's Avatar
wow, I would love to have that kind of horn
Old 04-15-2010, 01:34 PM
alfhasg35's Avatar
lol. i watched the video clip 3x and lol every time.. i may get this...
Old 04-17-2010, 05:01 PM
rhoward15's Avatar
you should get the viper one that talks when people touch car
Old 04-25-2010, 01:55 AM
avs007's Avatar
I upgraded my horn with a 139db Stebil Nautilus Air Horn. I bought it from here.
The install was pretty easy... I don't have a clip of it on my car, but
is a clip of it installed on a motorcycle...
It sounds similar to the horn on my friend's ferarri. It's also loud as fsck. If I remember correctly, the manual had a warning saying that the horn is audible for something like 3 city blocks or something like that. I know the db scale is logarithmic, but I remember reading that a handgun being fired is 140db.
But anyways, I'm super happy with this horn... And it was only $39. I looked at the Nismo horn before I bought this, and I remember people saying it wasn't that much louder than stock if any.... This horn is waaaaaaaaaay louder than stock....
I mounted it in the same location as the OEM horns, even using the OEM bracket in a creative fashion. Only drawback, is that if you use the horn notification when you arm the alarm, that won't work anymore, becuase the blip isn't long enough for the horn to activate. However, the horn still functions correctly if you trip the alarm.... Did I mention I rigged my clear-corners so my alarm goes off if you try to steal them?
It comes with a relay, as you'll need to use it... This beast draws > 10A of current, so that should give you an idea of how loud it is I used a 15A fuse and wires my own harness, and used the stock horn plugs as the triggers for the relay...
I also looked into hornblasters before I bought my horn. Those require an air compressor and a tank and everything. Plus they're expensive... This 139db horn isn't near as loud as a train horn, but it's way easier to install, and much friendlier on the wallet. It has the horn and the air pump integrated, so you don't need a tank or anything.
Old 04-25-2010, 01:59 AM
thescreensavers's Avatar
Mr.202?
^ sweet
Old 04-25-2010, 02:13 AM
avs007's Avatar
is a clip that illustrates something that nobody tells you about hornblaster train horns... You gotta turn on the compressors and spend some time filling up your tank.... I thought that was over the top, becuase I want my horns for use in emergencies cuz the stock horns suck... But I don't want to eat up trunk space with a stupid comressor and tank, and then worry about if the tank has enough air pressure in it....
  #30
Old 04-25-2010, 02:46 AM
avs007's Avatar
Just for completeness sake, here's a photo of the horns installed in my car... You can see they are neatly tucked close to the OEM location, directly behind the bumper bar.
Quick Reply: Has anyone upgraded their horn?
