G35 Fuel Filters/location....?
Old Feb 2, 2010 | 06:47 PM
gary c's Avatar
Do we have fuel filters on our G35s, if so where are they located? Did a SEARCH and found nothing about "Fuel Filters." I replaced the ones on my last Z every 30K miles but it was easy to see and replace....
Gary
Old Feb 3, 2010 | 08:23 AM
slim17265's Avatar
my owner manual says my 03 fuel filter is inside fuel tank
Old Feb 3, 2010 | 10:21 AM
gary c's Avatar
Thanks Slim, why would Nissan put it in an area where it could be replaced easily....
Gary
Old Feb 3, 2010 | 11:37 AM
GrocryGettr's Avatar
Nissan doesn't recommend changing them until 100K miles. It's not that hard to do. Wait until your tank is low, remove the rear seat cushion and there will be an access panel to the fuel tank hat. Relieve the fuel pressure, take off the lines and pull out the fuel pump assembly.
I would recommend replacing the pump as well as they have a tendency to fail on higher mileage cars causing hard start ups and drive-ability issues.
Old Feb 3, 2010 | 11:38 AM
GreenGoblin's Avatar
The goblin resurrection
^ correct
Old Feb 6, 2010 | 10:34 AM
Pratt's Avatar
yeuus +1
Old Oct 2, 2012 | 04:49 PM
Dani01c's Avatar
this makes total sense. My car right now sometimes takes for ever to crank apparently it has low fuel pressure upon start up. But not sure if its the filter or the pump thats bad. All I know is that on mornings it starts fine or when its really cold. Now if I iuse the car and in one hour I istart it it takes like 4 or 5 seconds until it cranks. Apart from that everything seems fine. Even though it seems as if my MPG has really gotten awful since this started.
Old Oct 3, 2012 | 04:45 PM
Sparda1123's Avatar
Holy thread revival batman!
Old Jan 26, 2014 | 02:34 PM
SVTMarkB's Avatar
I'm also going to give this a try now. Been having some hard start issues at 102k mi now.
Old Feb 16, 2014 | 07:30 PM
mikeb33's Avatar
Well.... Did you change it? Did it help?
Old Apr 26, 2014 | 04:40 AM
yosip1115's Avatar
You really won't have any issues with the filter. If you have any they are from pump failure. The cheapest option is going for a walboro aftermarket pump. The filter is a white mesh oversized screen before the pump inlet, like a fish tank net...
Old Apr 26, 2014 | 07:57 AM
Urbanengineer's Avatar
Worth going with the walbro for a stock car though? Your fuel delivery does not need to increase...?
Old Apr 25, 2016 | 01:10 PM
tiguy99's Avatar
Good thread!
Thanks for the info
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
brian_z
Jul 22, 2015 09:19 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
