wheel ??'s
Old Mar 1, 2010 | 11:16 PM
jknuttila's Avatar
wheel ??'s
im a bit of a noob to the g35 world, but anyways i have been searching for rims since i bought my g last summer.
i have decided on 19" forgestar f14's, i have always been a vmr fan and this is the closest to it im gonna get.
what would be the best offset?(i want an aggressive look)
would i need to buy anything else besides just the rims and tires or need any extra maintenance to put these on?
would these look okay without being lowered?
& anything else im missing?
current mods:
flat black grille, debaged, clear corners, 15%all around.
future:
roof overlay, front lip, jwt pop charger/ ztube, rear diffuser, lowering springs?...
any advice or suggestions help, thanks https://g35driver.com/forums/images/smilies/wink.gif
Old Mar 2, 2010 | 11:13 AM
LordFappington's Avatar
Are you a sedan or coupe? Also what widths are you going for?
Old Mar 2, 2010 | 03:35 PM
jknuttila's Avatar
i have a dg coupe, idk im trying to learn about all this and what would be the best.
Old Mar 2, 2010 | 03:38 PM
nghiars's Avatar
do you want a flushed look or are you going for poke?
Old Mar 2, 2010 | 03:55 PM
jknuttila's Avatar
i cant say i know the difference between flush and poke?
Old Mar 2, 2010 | 05:49 PM
flush is where the wheels sit directly underneath the fender usually within spec. poking out is self explanatory. Usually its with negative camber which is required to fit bigger wheels/width and higher offsets.
Old Mar 3, 2010 | 07:50 PM
jknuttila's Avatar
im leaning towards more of a poke look. im going with f19x9 r19x11
Old Mar 3, 2010 | 07:58 PM
I would go with a 5-10 offset in the front and close to 0 offset in the rear. Typical setups are 9.5/10.5 up to you. The difference you are looking at makes your front tires look skinny as hell though
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
