Need help! Stuck with drive belt change on 07 g35x!
Old Apr 10, 2010 | 12:01 AM
mxlaughlin's Avatar
2007 g35x. Trying to replace the drive belt. I got it off okay but can't get the new one on. I've found a lot of help for the g35's but the x is totally different. Has anybody done this before? Is there a way to adjust the tension? Any help would be greatly appreciated!
Old Apr 15, 2010 | 01:51 PM
bythabay's Avatar
What did you do to get the old one off?? When I've done this before, I would stick something in to hold the belt tensioner in the "loose" position. This would allow me to easily remove the old belt and install a new one. After the belt installation, I remove whatever I am using to hold the tensioner in place and the install is done after I make sure the tensioner is working correctly.
Old Apr 17, 2010 | 05:02 PM
rhoward15's Avatar
same problem happened to me
i just took car to local mechanic and they fixed it for $800
Old Apr 18, 2010 | 11:54 AM
ojeez11's Avatar
first make sure the belt you bought is the same size. 2nd make sure you are routing the belt the same way. 3rd make sure the tensioner is in a postition where all the it gives the most slack. dont know if you got auto tensionor or a manual tensionor. if its auto your gona have to hold it while you put the belt on if its manual u just have to keep backing it off till you have the slack you need.
and rhoward15 did u really pay 800$ to have a belt changed?
Old Apr 18, 2010 | 02:25 PM
duelper4mance's Avatar
I didn't have any problem at all when I changed my drive belts. Did you loosen the bolt in the center of the tensionor pulley, as well as the tensionor itself? That pulley should move enough so that the belt just slides right on if you're routing it correctly.
Old Apr 19, 2010 | 10:53 AM
mxlaughlin's Avatar
I figured it out. I had never seen a tensioner pulley, only the bolts that loosen the tension. Once I figured that out, I got it all back together. Thanks!
wuppiedog
Aug 7, 2015 11:16 AM
Mac8008
Aug 4, 2015 09:19 PM
kinetek
Aug 3, 2015 04:25 PM
rping
Jul 26, 2015 09:53 PM
justgotg35
Jul 19, 2015 12:33 PM
