Air/Fuel Ratio Sensor Meter????
Old Apr 13, 2010 | 05:39 PM
speedjunkie_G35's Avatar
I ran sea foam thru my car last week and now I have 2 codes P1031 - Air/Fuel Ratio Sensor Meter, and P1148. Where is the A/F Sensor located. I am wondering if I might of left it un plugged when I changed my spark plugs?
Any help is greatful.
Old Apr 13, 2010 | 07:03 PM
nghiars's Avatar
its behind the intake box beofre the z/g tube. AKA MAF sensor could probably use some cleaning.
Old Apr 13, 2010 | 08:53 PM
bigc's Avatar
Wings Nation
are you talking about the MAF sensor or the o2 sensors? If you're looking for the o2 sensors, there are four of them - 2 on each of the catalytic converters. one is up high near the header, the other is at the bottom near the y-pipe.
Old Apr 14, 2010 | 02:56 PM
I am not sure. Half of what I fould directed me to the MAF, and the other half said the O2 sensor. I am going to try and clean the MAF and see if the takes care of the problem.
Old Apr 14, 2010 | 02:58 PM
Forgot to say thank you. With out this forum and everybodies help, I would be running around looking like a chicken with his head cut off.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
