fuel level sensor?
Old Dec 7, 2011 | 11:44 AM
  #31
Z 2 G's Avatar
Originally Posted by Retaliation
Well, the driver side would be cheaper since just the sensor is $100. The passenger side which is the fuel pump as well is $270. It'd be worth doing one at a time to see if one fixed it before replacing both.
Before that though, I'd just clean off the copper contact points with a q-tip on both of the sensors. Mine used to have 7-8 gallons in the tank when it was showing empty and it never showed a full tank on the needle. Now when the light comes on, I have about 3 gallons. left, and the gauge shows full when I top it off. It's not ideal, but I'm much happier with the fix and it was free.
Ya i already did that and man was that a great fix, but it only lasted me about 2weeks. So, I need to replace them. I will try out the driver side first and go from there..
My concern, is where to buy them. I'm just wondering if there are other stores for cheaper
Old Jan 8, 2012 | 02:43 PM
  #32
Z 2 G's Avatar
where can i get the best deals on these sensors?
Old Jan 9, 2012 | 01:59 PM
  #33
GR6RR's Avatar
I would try again, maybe you didn't clean them well enough. I had to clean mine a second time after the initial few weeks. But since then, It's been working properly ever since. Give a good clean, although it doesn't look dirty, it very well can be.... Just a thought, it could save you the 270 your willing to spend
Old Nov 28, 2012 | 08:23 AM
  #34
racercris15's Avatar
Z 2 G did u ever fix the problem, ive been having this prob for like a year and half now, cleaned them twice and it just got worse
Old Dec 17, 2012 | 01:20 PM
  #35
ImIn06GT's Avatar
My fuel gauge stoped working, I replaced driver and passenger fuel level censor module, one was 117 and the other one was 123, I replaced it and it still does not work correctly, sometimes it shows the right amount, sometimes it doesn't... what did I miss????
Old Aug 29, 2020 | 09:26 PM
  #36
Tyrone Jackson's Avatar
G35
Possible fix
CJM Return Fuel Correction Kit
https://www.z1motorsports.com/fuel-s...pe-p-9003.html
g.spot
May 9, 2016 10:54 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
