Blower fan for climate ctrl not spinning - intermittent
Ok swapped the relay heat and AC blow great😌. I was able to grab the relay for $15 from Amazon!
AC blower motor not turning on
I have a 2008 Infiniti G37 coupe. My account doesn't not kick on period. There is no air coming from the vents. I replaced the blower motor along with a cabin air filter. And I replaced the blower motor relay like you guys mentioned. But that doesn't seem to do the trick. I have 4 blue relays in the back of my fuse box I replaced the bottom one. Should I also replace the accessories relay? AC compressor comes on just no air period.
You might want to swap the relays around, I don't know exactly which one it's supposed to be on a 2008 since that was the revision year. All 4 of those relays are the same though so you can just swap them in pairs so each one is moved to a different location.
I will try to swap the relays and give an update later on. I was also thinking of swapping them around. I was just a little disappointed that this worked for alot of g35s and not my G37 coupe. Lol yes that is the configuration. I did swap out the blower motor relay with the OEM blue relay. Still no air.
So I went ahead an rearranged the relay switches. I still do not have the fan turning on. I'm going back to autozone to see if the blower motor itself is faulty.
Thanks for the Diagram
I replaced it and it fit perfectly and once I turned on the Car the Heat came right on
I don't know why they placed it there as it was sooo difficult to find and even harder to replace
Thanks so much
Thank you All
The Dealer wanted $175 bucks to diagnose the issue and that didn't even include the price to fix or parts. In all they were going to charge me $300
I ordered the part from O'Riley's (part# 250347) with next-day shipping for an extra $12 and it fit.
I want to thank all of you for your input
Mine was located behind the fuse panel on the driver's side next to the emergency brake, its the bottom relay. Was a pain to unplug all of the wires in the cold, but popped in and now my Wife has heat for her morning commute.
Vern from Philly
Vern from Philly
I have a 2003 infiniti G35 sedan and have sorta have the same issue, i've replaced the blower motor and relay and still wont blow air, i did notice when i was replacing the old relay it melted the junction block a little but i was still able to replace the relay, any help guiding me to what i should do next would be appreciative
Learned Hand
Oct 1, 2015 09:02 AM
