Annoying sound in rear
Old Nov 19, 2010 | 01:48 PM
AARONHL's Avatar
How can I tell if my rear differential or wheel bearing is causing a LOUD PULSATING HUMMING NOISE??? I replaced the rear passenger wheel bearing about a year ago. I think the noise is coming from the rear driver side this time. There is no movement in the wheels when I raise the car. I think it's too loud to be the rear differential.
UPDATE: REPLACED REAR WHEEL BEARING AND THE NOISE STOPPED
Thanks,
Aaron
Old Nov 19, 2010 | 02:28 PM
DaveB's Avatar
Brake caliper/pad issue? E-brake issue?
Old Nov 19, 2010 | 02:34 PM
AARONHL's Avatar
I don't think so, the sound is really loud and I think a brake issue would cause a lighter, scraping type of noise. I start to hear the "jet engine" noise after about 40 mph and is louder than my exhaust on the highway.
Old Nov 19, 2010 | 02:39 PM
AARONHL's Avatar
My tires are new and the alignment is perfect. I'm pretty sure the noise is coming from the rear driver side...likely the wheel bearing.
I guess I'm asking if the rear differentials cause A LOT of noise?
Old Nov 19, 2010 | 03:21 PM
Sacch's Avatar
I am having that scraping sound, i guess i need to chage my pads.
Old Nov 19, 2010 | 09:46 PM
AARONHL's Avatar
Can the Rear Diff make pulsating droning noises?
Old Nov 19, 2010 | 10:22 PM
Siaon's Avatar
It could be your brakes.
I had that humming sound going ~50 mph on the highway.
Turns out my caliper was seized up and the brake pads were oddly worn.
Took it to the stealership and they replaced it no charge under extended warranty.
Old Nov 19, 2010 | 10:24 PM
AARONHL's Avatar
Hmmm Might inspect it tomorrow! It's a weird PULSATING WOOOOO WOOOOO WOOOOO
Old Nov 19, 2010 | 10:30 PM
Siaon's Avatar
Oh, pulsating?
Hmm, the sound I had was more along the lines of a sound that you would hear if you ran over one of those washboard-type roads on the shoulders of highways.
Old Nov 19, 2010 | 10:31 PM
Siaon's Avatar
EDIT; Double post. Sorry.
Old Nov 19, 2010 | 10:37 PM
AARONHL's Avatar
Low pitched, droning, humming pulsating noise. Hahahaha
Old Nov 19, 2010 | 10:43 PM
thescreensavers's Avatar
Mr.202?
The diff makes a whining noise.
Old Nov 19, 2010 | 10:47 PM
AARONHL's Avatar
I could describe the noise as tire road noise, but just PULSATING.
Old Nov 19, 2010 | 10:50 PM
Mr.202?
^ rotate the tires see if the noise moves to the front then you know its the tires. Easy enough to do.
Old Nov 19, 2010 | 10:59 PM
AARONHL's Avatar
It sounds like the noise is from the driver's side rear wheel. I switched the rear tires and the noise still sounds like it's coming from the driver's side rear wheel.
