Issue with screetching belt noise.
Old Dec 7, 2010 | 05:17 PM
  #31
VQEric's Avatar
One other thing to watch out for...maybe this is rare but it happened in my case. The tensioner adjusting bolt had been overtightened in an attempt to tighten a stretched belt. The overtightening of the bolt actually bent the ears on the tensioner "bracket" rendering it useless to sufficiently tension a new belt. The bracket is made out of pretty soft metal, so be careful. I tried beating mine back into shape with a hammer before giving up and pulling a tensioner bracket from a salvage G that I had access to.
If you're getting the correct belt tension with the gauge, then most likely not a bent bracket in your case, but wanted to post for others.
Old Dec 11, 2010 | 01:15 AM
  #32
Flipjnh's Avatar
Belt needs tightening, If its older than 2 years it needs replacement. Check all your pulleys including your Idler pulley the bearings might have worn out.
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
EricF
Aug 28, 2015 08:27 AM
Frostbite91
Aug 20, 2015 07:20 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
