2004 G35 sedan Driver seat problem
Old Nov 28, 2010 | 10:27 PM
Gorg3ou5's Avatar
2003 G35 sedan Driver seat problem
my driver seat is stuck on recline..its leaned back 75% it still able to recline but doesnt want to move forward...also my seat does not slide front or back anymore..anyone know whats wrong? mainly concerned about the recline, cause im not able to drive with my seat reclined almost all the way back...any suggestions what to check for? wires? fuses? thanks guys! please lmk
Old Dec 4, 2010 | 12:37 AM
R6n350GT's Avatar
Isnt recline a manual leaver down by the door on edge of seat???
Old Mar 4, 2011 | 10:01 AM
fmolinares's Avatar
Any FIX?
I am having the exact same issue with my 2003 G35 sedan. Did you ever find out how to fix this? Was it an expensive fix?
Old Apr 25, 2012 | 01:16 AM
Boostgod's Avatar
same here
Old May 1, 2012 | 08:07 PM
RADRaze2KX's Avatar
you guys have me trippin out, I got electric seats in my '04 sedan, too... haven't had that problem yet, though... underneath the seat, there's two or three wiring harnesses, make sure they're all secure... Open the driver's side rear door and squat down beside your car and look underneath the seat... If you still can't see the cables, you can unbolt the four bolts holding the seat down to the chassis of the car and tilt the chair forward/upward and check the cables (otherwise, it's somewhat difficult to see them)...
Your seat motors could be shot, also (just like window motors/actuators). Does the seat height still adjust up/down, does it still slide forward/back? There should only be one motor to replace if the other functions are still working.
There should also be a fuse that governs the movement of the chair, but I'm not sure which one it would be, never had chair problems and I've had my seats in and out of my G at least 6 times.
Good luck, let me know what you find out
Old Dec 20, 2012 | 12:08 PM
HOLLYARTS2's Avatar
I have a 2003 sedan and have had to change the plastic gear seat track assembly 3 times. Is there a replacement part for this gear? Will upgrading to the coupe seat and frame solve this problem?
Old Dec 20, 2012 | 12:09 PM
HOLLYARTS2's Avatar
2003 plastic seat gear
Old Dec 20, 2012 | 12:25 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
99.9% of the time, it's the seat switch that causes the problems, I have never heard of anyone having to replace the frame more than 1 time,......
Old Jan 27, 2013 | 06:18 PM
HOLLYARTS2's Avatar
I replace the track frame because I cannot get the plastic gear by itself. What is happening is that one side of the seat moves and the switch side does not. I have Bibb told the gear is the problem by an Infiniti service manager.
vmcarbuyer
Oct 12, 2019 12:42 PM
slider_ua
Jul 29, 2015 04:17 PM
vstypicals
Jul 20, 2015 10:55 PM
brian_z
Jul 20, 2015 01:30 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
