Questions about new rims and tires.
Old Dec 9, 2010 | 08:01 AM
noahonev's Avatar
I have a 2005 G35 coupe, and has recently got damaged from a curb. And since one wheel is dented up pretty bad, I figured I wanted to get new wheels. But I don't know if I should get a set of 19" wheels and the tires to fit the wheels for all 4, since I know their is a slight difference between the front two and the back two. So if I got the same size rims and same size tires for all four would that work? Or should I get the front two same size rim and same size tires, and then the back different from the front?
Old Dec 9, 2010 | 08:50 AM
LightsOut's Avatar
SIETESG
it doesnt matter.. it's really up to you.
my input is to go staggered, not same all around.
Old Dec 9, 2010 | 09:00 AM
noahonev's Avatar
staggered meaning front usually smaller than the front correct?
where could i find the rim size and tire size of the stock oem rims so i can get some rims
to match that set.
Old Dec 9, 2010 | 09:12 AM
LightsOut's Avatar
SIETESG
https://g35driver.com/forums/wheels-...s-offsets.html
instead of getting new wheels, try and get that curb rash repaired by a mobile wheel repair.
do a little searching...
Old Dec 9, 2010 | 09:28 AM
noahonev's Avatar
Thanks, but its just not that 1 wheel. front left is dented up and curb rashed around the rim. front right has curb rash around rim, and so does the back left and back right.
Old Dec 9, 2010 | 10:10 AM
LightsOut's Avatar
SIETESG
some guy is selling a nice set up wheels for 1300 with tires.
Old Dec 9, 2010 | 11:51 AM
noahonev's Avatar
Being that my car is 19 x 8 in the front and 19 x 8.5 in the back, can i use 19 x 8.5 in the front and 19 x 9 or 9.5 in the back?
Old Dec 9, 2010 | 12:28 PM
LightsOut's Avatar
SIETESG
yes
Old Dec 9, 2010 | 12:46 PM
noahonev's Avatar
and when putting rims that are smaller than OEM ( factory ) is that considered bad?
Old Dec 9, 2010 | 12:55 PM
LightsOut's Avatar
SIETESG
as longest the front and rear wheels are within 3% of each other.
it can be configured by using a tire calculator.
Old Dec 9, 2010 | 01:26 PM
noahonev's Avatar
like instead of getting 19 x 8 and 19 x 8.5, could i get 18 x 8 and 18 x 9.5 without messing up anything? and plus cheaper :/ lol
Old Dec 9, 2010 | 01:55 PM
LightsOut's Avatar
SIETESG
yes
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
multimut
Canada
Jul 26, 2015 08:43 PM
